1365
PerformAutoSize not working as expected
I have a Hierarchical Datagrid from version 12.1.
I load a collection of class Employee in de Datasource. Each Employee has a property Tasks which is a collection of class Task.The property Tasks however is always initially empty (so the grid is 1 level deep).
In my app the enduser can assign a Task to an Employee. The Task row needs to be shown beneath the Employee row, this all works fine. But I also need to autosize all the columns of all the rows. And I want to size everything so that all the data in the cells are visible to the enduser.
I try to do this in the InitializeLayout eventhandler, as follows:
        private void ultraGrid_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) {
            Infragistics.Win.UltraWinGrid.UltraGrid grid = (Infragistics.Win.UltraWinGrid.UltraGrid)sender;
            grid.DisplayLayout.Override.AllowUpdate = Infragistics.Win.DefaultableBoolean.False;
            grid.DisplayLayout.Override.CellClickAction = Infragistics.Win.UltraWinGrid.CellClickAction.RowSelect;
            grid.DisplayLayout.Override.SelectTypeRow = Infragistics.Win.UltraWinGrid.SelectType.Single;
            Infragistics.Win.UltraWinGrid.UltraGridLayout layout = e.Layout;
            Infragistics.Win.UltraWinGrid.UltraGridOverride ov = layout.Override;
            ov.AllowColSizing = Infragistics.Win.UltraWinGrid.AllowColSizing.Free;
            layout.Bands[0].Override.RowSpacingAfter = 2;
            layout.Bands[0].Override.RowSpacingBefore = 3;
            foreach (var band in layout.Bands) {
                band.PerformAutoResizeColumns(false, Infragistics.Win.UltraWinGrid.PerformAutoSizeType.AllRowsInBand);
                foreach (var col in band.Columns) {
                    col.PerformAutoResize(Infragistics.Win.UltraWinGrid.PerformAutoSizeType.AllRowsInBand, true);
The PerformAutoResize in the foreach loop is not giving me the result I expected. The added Tasks at level 2 in the grid are not resized at all so it seems. Can you please help me Infragistics? I need your expert advice on this one.
