145
Memory problems when using UltraChart in UltragridCells
I try to use ultraChart-controls in rows (about 5.000) of an ultragrid. The charts are computed in the InitializeRow-event of the grid, which calls the following method:
Private Sub SetChartControl(ByRef pRow As UltraGridRow, pValueList As List(Of Decimal))
Dim ucce As New Infragistics.Win.UltraWinEditors.UltraControlContainerEditor()
Dim dt As New DataTable
dt.Columns.Add("1", GetType(Decimal))
dt.Columns.Add("2", GetType(Decimal))
dt.Columns.Add("3", GetType(Decimal))
dt.Rows.Add(pValueList.Item(0), pValueList.Item(1), pValueList.Item(3))
Dim uc As New Infragistics.Win.UltraWinChart.UltraChart()
uc.ChartType = ChartType.LineChart
uc.DataSource = dt
uc.DataBind()
ucce.RenderingControl = uc
pRow.Cells("Orders").EditorComponent = ucce
End Sub
This leads to memory problems (SystemOutOfMemoryExceptions).
What's the best way to get the desired result without the memory leaks?
Thank you very much.
Regards, Marco
Parents Reply Children
No Data
