20
AllowAddNew row disabled when datatable contains zero rows
I have an UltraGrid whose DataSource is a datatable and has AllowAddNew set to FixedAddRowOnBottom.  If the datatable contains at least 1 row (dt.rows.count>=1) then I can click in the blank row and supply values for the new record.  However, if the datatable contains zero rows (dt.rows.count=0) then the blank row acts like it is disabled.  Meaning if I click in the blank row the backcolor of the cell does not change from gray to white, I do not get the vertical cursor bar, and everything I type is ignored.
What do I need to do so the user can create the first row?
Any help on this issue is greatly appreciated!
  • 469350
    Hi Karen,
    What version of the grid are you using? And what version of Visual Studio and the DotNet framework are you coding with?
    I vaguely remember there used to be some problems with the BindingManager and the DataTable class where it would not allow you to add a new row to an empty table. So the issue might not have anything to do with the grid.
    You might try using a BindingSource to wrap your DataTable and see if that helps.
