60
Show Scrollbar while Ultragrid Not Enabled
I'm new-ish to ultragrid so I don't know a whole lot. I have a defect where the scrollbar is not appearing when the ultragrid is not enabled so we have some records being cut off. ultragrid.Enabled = false but the scrollbar is not showing. I found somewhere that you can change the scrollbar to show if the column is in edit mode, but I don't want the column to be in edit mode. A 'hackish' way to get around it is to do ultraGrid.DisplayLayout.Override.AllowUpdate = false, but that doesn't seem right. It also makes the grid appear editable when it's not and it'll be confusing to the users. The only way I can think of is to put AllowUpdate to false and change the appearance of the grid, but there should be an easier way.
