Could somebody tell me whats wrong in below code. I get an error message while i try to add the below code in my project:
An unhandled exception of type 'System.ArgumentException' occurred in infragistics.win.v3.1.dll. Additional information: Can't add a ValueListItem to a value list item collection
Dim ValueListItem1 As Infragistics.Win.ValueListItem = New Infragistics.Win.ValueListItem
Dim ValueListItem2 As Infragistics.Win.ValueListItem = New Infragistics.Win.ValueListItem
ValueListItem1.DataValue = False
ValueListItem1.DisplayText = "Date/Facility"
ValueListItem2.DataValue = False
ValueListItem2.DisplayText = "Facility/Date"Me.optSort.Items.Add(ValueListItem1) - ERROR Here Cant add a valueListItem to value list item collectionMe.optSort.Items.Add(ValueListItem2)
Hello Shiv,
Thank you for your response.
Since your project was originally using NetAdvantage 2003 Volume 1, it's probably still being built against version 1 of the CLR. You need to change the project properties so the project is built against version 2.0 or newer of the CLR. In order to do this, you will need to use at least Visual Studio 2008 since earlier versions don't provide the ability to change the version of the CLR you are targeting. Once the project is targeting CLR2 or greater those errors should disappear.
Dave, I am sorry, still am getting err msg. I did add the dlls with ur utility to upgrade the references. But still it throws the err msg. Screenshot attched
Instead of trying to add the DLLs manually, you should use our Version Utility to upgrade the references that currently exist in your project.
You can find the Version Utility on the Start Menu inside the Infragistics folder.
Dave,
I tried adding the referrences but its throwing an error msg. Screenshot AttCHED
I'm a bit confused. You say you have NetAdvantage 2008 Volume 2 installed, but your list of references shows NetAdvantage 2003 Volume 1. Please verify which version you are using.
