Is there a way to retrieve a column by it's visible position? Rows can be accessed by index (visible position) or by listindex (data position). I can only find a way to access columns by data position.
There are a couple of ways you can do this. One way is to use the VisibleHeaders collection on the ColScrollRegion:
this.ultraGrid1.ActiveColScrollRegion.VisibleHeaders[1].Header.Column
If you want to loop through the columns in the visible order, then I would recommend using the GetFirstVisibleCol method on the band and then the GetRelatedVisibleColumn method on the column.
