The way I accomplished this with the Column Chart was by using one of the examples given in one of your documents. Mainly the function
private void UltraChart1_Column_ChartDrawItem(object sender, Infragistics.UltraChart.Shared.Events.ChartDrawItemEventArgs e)
I then followed the example you guys have posted and changed the stroke and strokewidth on the PE object to change the border color and to make it glow a green/red.
And from here I know that b is a bar I want.
Thanks a lot. Got it to work just like I needed.
I recently had to do something similar and not sure if it will give the same results as you are expecting but here goes...
My understanding (someone correct me if I'm wrong) is that once you have bound your data every DataPoint, PolyLine, PointSet etc is "in" the chart and can be accessed from the FillSceneGraph event of the UltraChart (windows not sure about web). Using this I added a local variable to hold the X/Y positions of the points and itterated through then and painted a new ellipse and added it to the chart scene. VB Code afriad - but if you are working in c# it is easy enough to translate :)
HTHBrendon
'Local VariablePrivate m_PaintPoints As New Generic.List(Of System.Drawing.Point
Private Sub UltraChart1_FillSceneGraph(ByVal sender As Object, ByVal e As Infragistics.UltraChart.Shared.Events.FillSceneGraphEventArgs) Handles UltraChart1.FillSceneGraph For Each p As Primitive In e.SceneGraph If (TypeOf p Is Polyline) Then For Each pt As Infragistics.UltraChart.Core.Primitives.DataPoint In CType(p, Infragistics.UltraChart.Core.Primitives.Polyline).points If pt.Value IsNot Nothing Then 'Points to paint in case there is only 1 point for the series Dim newPT As New System.Drawing.Point(pt.point.X, pt.point.Y) If Not m_PaintPoints.Contains(newPT) Then m_PaintPoints.Add(newPT) End If End If Next pt End If Next p
For Each paintPt As System.Drawing.Point In m_PaintPoints Dim myCircleRight As New Ellipse(paintPt, 3) myCircleRight.PE = New PaintElement(System.Drawing.Color.CornflowerBlue, System.Drawing.Color.OrangeRed, GradientStyle.Elliptical) e.SceneGraph.Add(myCircleRight) NextEnd Sub
