1635
Can I change DragWindwStyle's indicator?
I am using both UltraTabbedMdiManager & UltraDockManager. I set DragWindowStyle property  to LayerdWindowWithIndicators.
But, I 'd like to remove the dockable arrow from the indicator, because I want the pane to go into Tab.
So, Can I change the indicator arrow such as removing four arrows from the indicator like below?
  • 23930
    I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
  • 23930
    After into your request and doing some research, "Removing dockable arrow from the DockIndiicator" has been determined to be a new product idea. You can suggest new product ideas for future versions (or vote for existing ones) at <http://ideas.infragistics.com>.
    There are many benefits to submitting a product idea:
    -          Direct communication with our product management team regarding your product idea.
    -          Notifications whenever new information regarding your idea becomes available.
    -          Ability to vote on your favorite product ideas to let us know which ones are the most important to you.  You will have ten votes for this and can change which ideas you are voting for at any time.
    -          Allow you to shape the future of our products by requesting new controls and products altogether.
    -          You and other developers can discuss existing product ideas with members of our Product Management team.
    Steps to create your idea:
    1.       Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
    2.       Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
    3.       Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
    The Product Idea site puts you in the driver’s seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
    Thank you for contacting Infragistics.
