I am using both UltraTabbedMdiManager and UltraDockManager.
After floating the pane from the tab group, if I double click floating pane, it does not come back to tab group, but go into another dockArea.
Is there any way to change this?
Here is the sample:
Hello guidegi,
The mentioned behavior is expected in scenario, when you floating a pane from TabbedMDIControl . After double clicking on the pane, this pane will be docked, but not like a MDIChild, that`s why go into another dockArea. To solve this task, you could handle BeforeToggleDockState() event and include the code below:
private void ultraDockManager1_BeforeToggleDockState(object sender, CancelablePaneEventArgs e)
if (e.Pane.DockedState == DockedState.Floating && e.Pane.Tag == "IsMdiTabbed")
e.Cancel = true;
((Infragistics.Win.UltraWinDock.DockableControlPane)(e.Pane)).IsMdiChild = true;
if (e.Pane.DockedState == DockedState.Docked && ((Infragistics.Win.UltraWinDock.DockableControlPane)(e.Pane)).IsMdiChild)
e.Pane.Tag = "IsMdiTabbed";
else
e.Pane.Tag = null;
Please take a look on attached sample and video file for more details and if you have any questions, feel free to write me
Regards
