HI,
I've tried using the following code to bind the notes to UltraCalendarInfo, but after binding, the Notes collection is still empty:
this->ultraCalendarInfo1->DataBindingsForNotes->SetDataBinding(this->dataset, "Table1");this->ultraCalendarInfo1->DataBindingsForNotes->DateMember = "DateTimeStart";this->ultraCalendarInfo1->DataBindingsForNotes->DataKeyMember = "id";this->ultraCalendarInfo1->DataBindingsForNotes->DescriptionMember = "Description";// after the above code this->ultraCalendarInfo1->Notes is still empty
------------------------------I've tried the same with appointments (DataBindingsForAppointments) by binding to the same table, and set the StartDateTimeMember and EndDateTimeMember, and after that, the Appointments collection is automatic filled with all the data. Is there any reason why the Appointments collection can be populated by databinding while the Notes collection can't? Is this a bug (I'm using 8.1.20081.2033)?
Thanks!
Try adding the following line:
this->ultraCalendarInfo1->DataBindingsForNotes->BindingContextControl = this;
