800
Add item to binding list not AfterRowInsert event
I'm using a pretty simple WinGrid that is bound to a BindingList of custom objects.  When adding new items to the list, I'm not using the WinGrid to do so, because the objects need a bit of initialization (ie. there is no default constructor).  Instead, I am creating the object, initializing it and then adding it to the BindingList.  The WinGrid is picking up the new object and adding a new row for it, however I want the grid to make that new row active.  I thought that the AfterRowInsert event would be raised in this case and I could just set the active row here, but that event simply isn't being raised. Am I missing something here?  Is there some other event I can get when this happens?
