I am using
Infragistics.Win.UltraWinChart.UltraChart as a GanttChart
I want to be able to move the Y colum label section like splitter, by moving the slider bar horizontally left or right so that if the column lables are too long and copped; by sliding [moving] the Y Axis into the chart full lables text can be seen.I do change the Axis.Y.Extent value if the Chart SizeChanged Event, but I am looking for a bit more sophisticated logic.Could you please advise?Kind Regards
Hi Dimitar,
I have posted another question, I didn't have a solution response yet. It has been a long time.
Could you please check the following question, I will appreciate.
http://ko.infragistics.com/community/forums/t/87335.aspx
Kind Regards,
Thank you that explains alot.
Hi Zafer,
Thank you for the reply.
You should be able to compile the software as long as you don’t change anything about it. If you try to change something in the designer it should not work. Also the license file was empty, because if it isn’t you won’t be able to build the solution – the application won’t be able to find the PublicKey and you might be using different service release than me.
Please let me know if you have any additional questions.
Thank you for the solution you have provided earlier.I have downloaded and seen you solution working how it supposed to work.
At the moment my trial licenses are expired, I am waiting that issue to be solved internally.
I was expecting your solution to have failed the compilation due to license expiry failure. Despite your licenses.licx file being empty, your solution compiles without error.
I just wanted to let you know.
Should I be able to compile this software without a valid license?
Hello Zafer,
I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
