I have an UltraWinGrid that gets loaded with data every time the user clicks on a refresh button. The new data is loaded into the UltraWinGrid by setting the DataSorce member to a new DataTable each time.
The grid is set up to allow the user to group the columns, sort on columns, or filter data using any of the columns. I need to preserve the grouping, sorting, and filtering. I have succeeded at doing that using the following methods:
Private sortIndicator As List(Of Infragistics.Win.UltraWinGrid.SortIndicator) Private filterConditions As List(Of Infragistics.Win.UltraWinGrid.FilterConditionsCollection) Private isGroupByColumn As List(Of Boolean)
Private Sub GetFlatColumnSortOrder()
Dim columnCount As Integer = grdServer.DisplayLayout.Bands(0).Columns.Count If (columnCount > 0) Then sortIndicator = New List(Of SortIndicator)(columnCount) filterConditions = New List(Of Infragistics.Win.UltraWinGrid.FilterConditionsCollection) isGroupByColumn = New List(Of Boolean) For index As Integer = 0 To columnCount - 1 sortIndicator.Add(grdServer.DisplayLayout.Bands(0).Columns(index).SortIndicator) Dim columnFilterConditions As Infragistics.Win.UltraWinGrid.FilterConditionsCollection = grdServer.DisplayLayout.Bands(0).ColumnFilters(index).FilterConditions filterConditions.Add(columnFilterConditions) isGroupByColumn.Add(grdServer.DisplayLayout.Bands(0).Columns(index).IsGroupByColumn) Next index End If End Sub
Private Sub SetFlatColumnSortOrder() If (sortIndicator IsNot Nothing) Then Dim columnCount As Integer = grdServer.DisplayLayout.Bands(0).Columns.Count For index As Integer = 0 To columnCount - 1 If (isGroupByColumn(index)) Then Dim descending As Boolean = False If (sortIndicator(index) = Infragistics.Win.UltraWinGrid.SortIndicator.Descending) Then descending = True End If grdServer.DisplayLayout.Bands(0).SortedColumns.Add(grdServer.DisplayLayout.Bands(0).Columns(index), descending, True) End If grdServer.DisplayLayout.Bands(0).Columns(index).SortIndicator = sortIndicator(index) grdServer.DisplayLayout.Bands(0).ColumnFilters(index).ClearFilterConditions() For Each fc As FilterCondition In filterConditions(index) grdServer.DisplayLayout.Bands(0).ColumnFilters(index).FilterConditions.Add(fc) Next Next (index) grdServer.DisplayLayout.Bands(0).Groups.Clear() End If End Sub
GetFlatColumnSortOrder() gets called before the DataSource is set and SetFlatColumnSortOrder gets called after the DataSource is set.
Everything works fine except that the current state of the groups (whether or not they are open or closed in not being preserved. If groups are set up by the user and the user has opened them, then after the Refresh button is pressed, the columns to be grouped appear in the group box and all filters and column sorting orders are correctly preserved, but all the groups are closed (so the user has to click on the + signs in the tree to reopen the ones he wants to be opened.
How do I save and restore the status (open/closed) of the groups?
Andy
My guess is that the active GroupByRow is not highlighted at all. But when you click on the row, it's getting selected and that's the highlight you are seeing. So in addition to the setting the ActiveRow, you probably just need to set the Selected property on the row to true.
Thanks Mike I got it to work, so the open groups are opened (if they still exist) when the data is refreshed.
Now I am trying to set the active row, so that row is highlighted.
It works fine for a row that contains data, but it doesn't completely work for a header row. The proper header row is set as active, but the row is not being highlighted by the grid. (In the case of a data row, the active row is highlighted).
What do I have to do to get the active header row to be highlighted?
Well... presumably you need two pieces of information to identify the row. The first is the GroupByColumn that the row belongs to. The second is the Value of that row.
You can get both of these very easily. Cast the row into an UltraGridGroupByRow and then you can access the Value and Column property.
Thanks Mike.
I think I see how I can do this. Only about 10% of the rows should be different with each refresh, so if I have a way to uniquely identify the row's group, I can save that it's state (expanded/closed). Is there a good property to use to identify the row group?
It may work out to be easier and faster for me to add a second grid, so I can simply modify the data in my dataset and not ever change the data source, instead of resetting the data source each time.
Hi Andy,
If you are losing the groupings, then you are probably setting the grid's DataSource or calling the SetDataBinding method. So you are attaching to a new data source.
In such a case, keeping the same groups expanded is not really possible, because the groups are dependent on the data, and you are applying a new set of Data to the grid. The old data isn't there any more and there's new data in it's place and the grid has no way of associating the old data with the new data.
The only way this could work is for you to handle it yourself. That means looping through every row in the grid (recursively if there is more than one level of grouping) and then recording the expanded state of each GroupByRow, based on the Value. Then you would have to loop through every row again after you changed the data source and examine each row, see if a matching Value exists in the recorded information and expand that row, as needed.
If you are looking for a simpler solution, then I'm afraid there isn't one.
