Hello!
I have just started to use the WinGauge control and I am a bit uncertain about some things.
I have focused on radial gauges so far, and I have used a preset that is available in the standard windows forms 13.2 edition of the controls. The
preset that I have used is the one that shows two different needles, one showing hot/cold and one showing full/empty.
Questions:
1. Is there a way to get some sort of values printed out automatically that shows the value of the needle. ? I have seen that there are tick marks (major/minor) but I don't know if they can do more than just showing a line in different places. There are also some event "Render Label" but I don't understand how to se that.
2. Is there som way to invert the needle value scale? What I mean that depending on the left and right gauge, the needle value 15 in both these gauges gives a mirrored appearance. One needle is in the bottom, one in the top. But that is of course the radial way ;-)
Next to the needle value, there is a precision setting. How does that work.? (In the gauge designer).
Sorry for the bad writing, difficult to explain this. For me anyway ;-)
/Henrik
You can set labels on the gauge to show a level of measurement and aid the needle. Most of the core functionality is exposed from the gauges > scales properties. The "RenderLabel" event will fire whenever a label is rendered on the Gauge.
For more information about lables please visit: http://help.infragistics.com/doc/WinForms/2013.2/CLR4.0/?page=WinGauge_Labels.html
The precision property snaps the needle to a certain tickmark closest to the to value; used to rounding values. For more details please visit the properties documentation.
http://help.infragistics.com/doc/WinForms/2013.2/CLR4.0/?page=Infragistics4.Win.UltraWinGauge.v13.2~Infragistics.UltraGauge.Resources.GaugeMarker~Precision.html
There isn't built in functionality to invert the needle nor the labels because the Axis cannot have an EndValue higher than the StartValue. You can submit a new product idea on our ideas page at ideas.infragistics.com
Let me know if you have any questions regarding this matter.
Here comes an image of the gauge i am using...
