Hello, i have the grid with multibands.
I need to hide first empty columns with empty data and prolong line to first cells with data.
It's clear how to hide column with empty data. I use Hidden Property - but i need that first cells with data do not move on place of empty cells.
I attached image describing what i want to get.
Thanks in advance.
There's no easy way to do exactly what you have here. You can set the Hidden property on the Cell, rather than on the column, and this will get you most of the way there. But the expansion indicators will not shift over like you have here.
Doing that would require a CreationFilter, and a pretty complex one, and even then I'm not sure it would be possible.
