4165
Error when unchecking a node.
I have a tree with two nodes. One node and then a child node
Node Parent
     Node Child
The child is using the checkbox style. The parent is not.
When I uncheck the node, when the after_check event is finished: (version 13.2.20132.2023)
ystem.NullReferenceException: Object reference not set to an instance of an object.
   at Infragistics.Win.UltraWinTree.UltraTreeNode.NodeUiaProviderStub.GetParent()
   at Infragistics.Win.UIAutomation.Stubs.FragmentUIAProviderStub.GetParentStub()
   at Infragistics.Win.UIAutomation.Stubs.FragmentUIAProviderStub.GetAutomationId()
   at Infragistics.Win.UltraWinTree.UltraTreeNode.NodeUiaProviderStub.GetAutomationIDInternal()
   at Infragistics.Win.UltraWinTree.UltraTreeNode.VerifyNodeUiaProviderStub()
   at Infragistics.Win.UltraWinTree.UltraTreeNode.GetUiaProviderStub(Boolean createIfNeeded)
   at Infragistics.Win.UltraWinTree.UltraTreeNode.GetUiaProviderStub()
   at Infragistics.Win.UltraWinTree.NodeCheckBoxUIElement.DoClick()
   at Infragistics.Win.UltraWinTree.NodeCheckBoxUIElement.OnClick()
   at Infragistics.Win.ControlUIElementBase.ProcessMouseUpHelper(Object sender, MouseEventArgs e)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseUp(Object sender, MouseEventArgs e)
   at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
   at Infragistics.Win.UltraControlBase.OnMouseUp(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
