570
winListView drag an drop to winGrid not working
Can someone help me! See attachment if needed.
Dim tblGridDragTo As New DataTable("EmployeDragTo")
Private lastMouseDown As Nullable(Of Point)
Private Sub Form1_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
lastMouseDown = Nothing
'winListView - DragFrom
UltraListView1.AllowDrop = True
UltraListView1.ItemSettings.LassoSelectMode = LassoSelectMode.LeftMouseButton
UltraListView1.ItemSettings.SelectionType = SelectionType.Extended
UltraListView1.View = UltraListViewStyle.Tiles
UltraListView1.ViewSettingsTiles.SubItemsVisibleByDefault = True
UltraListView1.MainColumn.Key = "id"
UltraListView1.MainColumn.DataType = GetType(Integer)
UltraListView1.MainColumn.Text = "Number"
'Columns
Dim c As UltraListViewSubItemColumn
c = UltraListView1.SubItemColumns.Add("Name")
c.DataType = GetType(String)
c.Text = "Employe"
'Items
Dim i As UltraListViewItem
i = UltraListView1.Items.Add("1", "1")
i.SubItems("Name").Value = "Robin Piche"
i = UltraListView1.Items.Add("2", "2")
i.SubItems("Name").Value = "Daniel Jutras"
'winGrid - DragTo
tblGridDragTo.Columns.Add("Number", GetType(Integer))
tblGridDragTo.Columns.Add("NAme", GetType(String))
tblGridDragTo.Rows.Add("3", "Martin Renaud")
UltraGrid1.AllowDrop = True
UltraGrid1.DataSource = tblGridDragTo
End Sub
Private Sub UltraGrid1_DragOver(sender As Object, e As System.Windows.Forms.DragEventArgs) Handles UltraGrid1.DragOver
e.Effect = DragDropEffects.Copy
End Sub
Private Sub UltraGrid1_DragEnter(ByVal sender As Object, ByVal e As System.Windows.Forms.DragEventArgs) Handles UltraGrid1.DragEnter
End Sub
Private Sub UltraGrid1_DragDrop(ByVal sender As System.Object, ByVal e As System.Windows.Forms.DragEventArgs) Handles UltraGrid1.DragDrop
'Remove the item from the current listview and drop it in the new listview
With CType(sender, UltraListView)
If e.Data.GetDataPresent(GetType(UltraListViewItem)) Then
Dim draggedItem As UltraListViewItem = CType(e.Data.GetData(GetType(UltraListViewItem)), UltraListViewItem)
MsgBox(draggedItem.Key)
End If
End With
End Sub
Private Sub UltraListView1_DragEnter(sender As Object, e As System.Windows.Forms.DragEventArgs) Handles UltraListView1.DragEnter
End Sub
Private Sub UltraListView1_MouseMove(sender As Object, e As System.Windows.Forms.MouseEventArgs) Handles UltraListView1.MouseMove
If Me.lastMouseDown.HasValue Then
Dim dragSize As Size = SystemInformation.DragSize
Dim dragRect As New Rectangle(Me.lastMouseDown.Value, dragSize)
dragRect.X = CInt(dragRect.X - (dragSize.Width / 2))
dragRect.Y = CInt(dragRect.Y - (dragSize.Height / 2))
If Not dragRect.Contains(e.Location) Then
Dim itemAtPoint As UltraListViewItem = UltraListView1.ItemFromPoint(e.Location)
UltraGrid1.DoDragDrop(itemAtPoint, DragDropEffects.Copy)
End If
End If
End Sub
Private Sub UltraListView1_MouseDown(sender As Object, e As System.Windows.Forms.MouseEventArgs) Handles UltraListView1.MouseDown
' Record the cursor location
If e.Button = MouseButtons.Left Then
Me.lastMouseDown = e.Location
Else
If UltraListView1.ActiveItem IsNot Nothing Then
UltraListView1.Items.Remove(UltraListView1.ActiveItem)
Me.lastMouseDown = Nothing
Else
End If
End If
End Sub
WinListViewDragToWinGrid.zip
