Hi,Does the UltraCellProxy that is contained inside a RowEditTemplate have a vertical scrollbar? I cant see that it does inside both properties (EditTemplate & CellProxy). At the moment the user has to drag down the mouse to reveal the text that doesn't fit when the RowEditTemplate first appears.CheersChris
in below given code snippet i am checking where column StatusImage exist or not then i am trying to sort StatusImage.
problem with this code is when there are number of sorted column after statusImage. below code removes status image from let say 3 position and add status image at the end of the sortedcolumn group. therefore column sorting position changes.
please suggest me the code which does following:
1. sorting with status image column.
2. index position for sorted column should not change..
if (ultraGridReaders.DisplayLayout.Bands[0].SortedColumns.Exists("StatusImage")) {ultraGridReaders.DisplayLayout.Bands[0].SortedColumns.Add("StatusImage", false, true);
Hi Chris,
The Proxy takes it's cue from the grid column. the column doesn't show a scrollbar by default, either. But you can turn this on by setting VertScrollBar on the column to true. This will effect the cell and/or the proxy alike.
