341
UltraCalculatorDropDown (version 8.1) Allows Invalid Characters
When the calculator is not dropped down the field allows entry of non-numeric characters.  Particularly problematic is that it allows multiple decimals (i.e. 3..4)   I have a solution that works (basically tap into the value changed event/strip out invalid characters), but it's a real hack.  Is there a better way to block invalid characters?
  • 71886
    Hello Jeff Staddon,
    Another approach to achieve this might be the following:
            private void ultraCalculatorDropDown1_KeyPress(object sender, KeyPressEventArgs e)
                if (!char.IsNumber(e.KeyChar))
                    e.Handled = true;
    You could modify the code to fit your requirements.
    Please do not hesitate to contact us if you need any additional assistance.
