If I have some rows activation set to disable and the drop down is not showing. I can down and up arrow and the disabled items are skipped. If I use the wheel mouse it selects the row even if the row is disabled. Unlike most of the posts I have read I don't want to disable the wheel mouse I just want it to act like the up and down arrow does.
I have attached a small sample that should replicate the issue described above. When I down or up arrow a row set to activation Disabled never fires the row selected event. When I use the mouse wheel it does.
Any suggestions on how I can prevent this?
Hello Michael,
I just wanted to add that the Development ID of the issue, which I submitted in our internal issue tracking system is 169724.
Hi Michael,
I have created support ticket for this issue – CAS-134920-J4M3Q0, in order to be able to log this for further investigation of our developers. As soon as I have more information for you I will update your case.
Thanks for the quick response. I will just wait for the fix. Thanks again.
That looks like a pretty clear-cut bug to me. I will ask Infragistics Developer Support to write this up for developer review so we can get it fixed.
