1125
WinGanttView - Scroll bar doesn't scroll range set in UltraCalendarInfo
HI
I'm getting the same behaviour as described here http://ko.infragistics.com/community/forums/t/87468.aspx whereby when you grab the timeline's scroll handle all move it all the way to the right of the scrollbar it does not move you to the end of the last task in the project.  If you run the attached example, don't resize the form, and grab the scroll handle and scroll all the way to the right you should see the issue, i.e. that the last visible date is now around 11 May rather than a date in June when the last task ends.
The link above states that the Gantt uses the dates in the UltraCalendarInfo to set the ranges for the scrollbar.  I have tried changing those dates in that example too, but as far as I can see that makes no difference; moving to the scroll handle to the far left does not take me to 1 Jan 2012 and moving it to the far right does not take me to 1 Jan 2015 (the dates I have set in code).
I think the desired default behaviour for most use cases is that the scroll bar handle would take you from the date of the start of the first task to the date of the end of the last task.
As with the other one I've just reported, a swift response would be greatly appreciated.
Thanks, Tom
IG Gantt Issues.zip
