I have a few questions I have not found answers to. Note that my column chart only ever shows seven data points.
1. Is it possible to shift the axis major gridlines so to place them in the middle of the gap between series? Or can I add a margin to the column bar so it does not take up the entire area like how it is shown in "CategoryXAxis" here: http://help.infragistics.com/Help/Doc/Reporting/2012.2/CLR4.0/html/Chart_Control_Chart_Axes.htmlThat spacing with the bar and the gridlines is what I am trying to accomplish such that there is a gap between the line and the bar as shown here. (This is the image from that page)
2. Is it possible to use other functions like IF() in the ChartText and Labels ItemFormatString? I want to add extra text but not have it show when the value is ZERO.If not then what is the best way to handle this.
3. Is it possible to show data in the labels from other hidden fields in the data source? If not is it better to use the IRenderLabel interface or just have code manually fill in that data as fixed text? Note that I would like to show this as a second row of centered data & have found the best way to handle that is to use a second ChartTextAppearance with a new line followed by a space at the end. This appears to be the only way to get each row in the label to center independently.
I appreciate your quick assistance with these questions.Seradex.
I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
Thank you for contacting Infragistics Developer Support.
I have attached my sample in order to demonstrate this suggestions.
Please let me know if you have any additional questions.
