I've upated my whole solution from Infragistics 2011.2 to 2014.1 with the version utility. This worked fine but now I am not able to load the dockmanager-settings, because they have been written under 2011.2. Is this a known issue? Do I have to delete the old settings? This would be bad since all our customers would loose their settings because of this update.
I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue?
Thank you for using Infragistics Components
Thank you for your feedback.
Without sample that demonstrates this issue, we cannot continue investigation for the root of this issue . So please collaborate and upload simple sample that demonstrates your issue, or just modify my sample, and I will be glad to investigate this further for you. For now I could verify that your layout file is loaded without any exception from UltraDockManager of Infragsitics 14.1, and my sample proves this. So if you are not able to isolate this in a separate simple, is it possible to upload the designers cs file of the form on which this exception occurs, and I will try to reproduce this on my side.
this gets way too time consuming. I've stopped the update and I will stay on the old version for the moment.
Maybe this issue will be fixed in a future version...
Is it possible to isolate this issue in a separate sample (or just modify the sample which I’ve uploaded with my previous response ), in order to be able to run it on my machine and to investigate this further for you.
I am waiting for your feedback.
I updated to the service release 2019 but unfortunately that did not help. I don't know why it works for you but I am not able to load old settings.The dock manager is initialized when the settings are loaded. This code runs on Infragistics since 2008 or even earlier and it is definitely an update problem. Once I have deleted the old settings and created new ones, everything works fine.
