485
ShowQuickAccessToolbarAddRemoveMenuItem error
Using Tag as mark for avoid the QuickAccessToolbarAddRemoveMenuItem this code makes nothing, the item appears.
Debugging all is ok, e.ShowQuickAccessToolbarAddRemoveMenuItem is set to false but the item appears.
private void tbManager50_BeforeToolbarListDropdown(object sender, BeforeToolbarListDropdownEventArgs e)
     if (e.Tool.SharedProps.Tag != null)
          if (e.Tool.SharedProps.Tag.ToString() == "NOQAT")
               e.ShowQuickAccessToolbarAddRemoveMenuItem = false;
