1735
Changing the Back Color of UltraWeekView/UltraDayView
Hi ,
I tried using below  sample of code that was suggested in one the post to apply back color for the selected daterange and time slot,  but its not working as expected.
http://ko.infragistics.com/community/cfs-file.ashx/__key/CommunityServer.Components.PostAttachments/00.00.44.16.67/UltraDayViewBackColor.zip
I have attached the snap shots of actual and expected outputs. When i selected daterange from 21 july to 24 july 2014, the time slot from 9pm to 11pm and color to Yellow, it gives the back color from 21 july 9m to 24 july 11pm. What I wanted was to give the color for each day from 9pm to 11pm i.e. on 21st 9pm-11pm then 22nd 9pm-11pm and so on.
Please sugguest me with solution.
ColorTimeSlot_Again.zip
  • 23930
    Hi Chitra,
    I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
  • 23930
    Hi Chitra,
    Thank you for contacting Infragistics Developer Support.
    The sample that you have linked simply checks if the timeslot is between the date range and if it is it colors that timeslot. It doesn’t check for the hour, it colors every time slot between the two dates. I have modified the sample and I have added a check which checks for the timeslot (please see the attached sample).
    Please let me know if you have any additional questions.
    WS_SpecificTimeSlotColor.zip
