185
PerformAutoResizeColumns() very slow in 14.1
Whenever we refresh an Ultragrid control in our project, we make the following specifications (control is referenced here as "fg"):
fg.DisplayLayout.Override.CellClickAction = UltraWinGrid.CellClickAction.RowSelect
fg.DisplayLayout.Override.SelectTypeRow = UltraWinGrid.SelectType.Extended
fg.DisplayLayout.Bands(0).Columns(0).Hidden = True
fg.DisplayLayout.Override.AllowUpdate = DefaultableBoolean.False
fg.DisplayLayout.Override.DefaultRowHeight = 25
fg.DisplayLayout.Override.HeaderClickAction = UltraWinGrid.HeaderClickAction.SortSingle
fg.DisplayLayout.Override.RowAppearance.TextVAlign = VAlign.Middle
fg.DisplayLayout.ScrollStyle = UltraWinGrid.ScrollStyle.Immediate
fg.DisplayLayout.ScrollBounds = UltraWinGrid.ScrollBounds.ScrollToFill
fg.AlphaBlendMode = AlphaBlendMode.Disabled
fg.DisplayLayout.MaxRowScrollRegions = 1
fg.DisplayLayout.MaxColScrollRegions = 1
fg.DisplayLayout.Override.RowSizing = UltraWinGrid.RowSizing.Default
fg.DisplayLayout.PerformAutoResizeColumns(False, UltraWinGrid.PerformAutoSizeType.AllRowsInBand)
When our developers were using Infragistics version 12.1 we experienced no substantial slowdown with those specifications but upon upgrading to version 14.1 loading large datasets became very slow. We tracked this slowdown to the PerformAutoResizeColumns call. If we comment out this one line in the refresh, loading up an UltraGrid with ~17,500 rows takes roughly two seconds. However, if we un-comment that line and the control performs the re-size the reload takes approximately 40 seconds. This is slow load is unacceptable to our customers and this scenario is not uncommon at all. Is there something in the way we're calling PerformAutoResizeColumns or the way we're setting the Ultragrid properties that is causing this massive loadtime?
Thank you,
Bob
