505
Popup menu won't stay open in MFC app
I have an issue similar to
http://ko.infragistics.com/community/forums/p/4936/267424.aspx
except that DockWithContainer is not helping here.
I believe the problem is caused by the special way that our application is set up: It's WinForms running inside an MFC window. The reason for this set-up is that the app must be an ActiveDocument server, and we've used MFC to create the ActiveDocument skeleton.
This has caused minor issues in the past, like menus and combobox drop-downs not closing when the app loses its focus, but so far we've been able to live with those. But now we have the problem that once our pop-up menu has shown a submenu and the user moves the mouse to another menu item (so that the submenu should go away), the entire popup disappears. This is a major usability issue.
My favorite approach would be to do without the UltraToolbarsManager, but apparently the PopupMenuTool cannot work without it.
The goal is to create a control, derived from UltraDropDownButton, that displays a drop-down menu. To make it self-contained, it needs to have its own UltraToolbarsManager and dynamically create the menu in the DroppingDown event. I have this working nicely in a small test app, but I'm hitting a wall in our real app.
Any ideas on where to look to make this work?
TIA,
Hans
