Hello All,
I have an ultragridprintdocument that prints a grid using the UltraPrintPreviewDialog. I have noticed that when printing from different computers will produce different size text (from some computers, the text of the rows is bigger, while from others it is smaller and hard to read). Comparing samples both print jobs have the same margin, its just the row size and text size differ. Has anyone seen this behavior before?
Hi Chris,
Thank you very much for the provided sample.
I have logged this issue in our internal tracking system with ID 177001 and also created a case for this - CAS-139346-N8P2S3. You can view your active support cases from the following link:
https://ko.infragistics.com/my-account/support-activity
I was able to create a sample. I noticed that once i changed the window state of the main form, that is when i started having the issue.
Thanks for following up, but at this time, i do not have the time to create a sample. Since changing the resolution worked, we have moved on until i can find some time to create a sample for you.
Hello Chris,
I am still following this thread. Have you been able to reproduce the issue in a separate sample? Let me know if you need my further assistance on this issue.
Thank you for the update.
Let me know when you are able to create the sample. I will be glad to research it.
I am looking forward to your reply.
