555
ExclusiveColScrollRegion is null, column appears twice
I would like to implement a grid where the columns appear only once in one of two ColScrollRegions:
Col 1,2 in ColScrollRegion0 and Col 3, in ColScrollRegion1.
Belonging to some former post I have to set the column header ExclusiveColScrollRegion property to the desired ColScrollRegion.
But it doesn't work: the col 1-3 appear still in both ColScrollRegions and the ExclusiveColScrollRegion property remains null after assignment.
Here is the code
private void ultraGrid1_InitializeLayout(object sender, InitializeLayoutEventArgs e)
UltraGridLayout layout = e.Layout;
ColScrollRegion colScrollRegion2 = new ColScrollRegion(1);
layout.ColScrollRegions.Add(colScrollRegion2);
UltraGridBand band = layout.Bands[0];
band.Columns[0].Header.ExclusiveColScrollRegion = layout.ColScrollRegions[0];
band.Columns[1].Header.ExclusiveColScrollRegion = layout.ColScrollRegions[0];
band.Columns[2].Header.ExclusiveColScrollRegion = layout.ColScrollRegions[1];
Whats wrong, thanks for a hint.
kagel
