Has anyone else had issues with the gauge designer where it crashes and has paint issues in regard to the controls for setting the different values of the object? Is there an end user solution to the issue or do you know if there is a patch for this?
I have been using the Gauge Designer for two days now and I have not been able to consistent figure out what triggers the gauge designer to crash but it does it so frequent that I have to apply the changes each time I change one item. It definately appears that unhandled exceptions are occurring because when it crashes the UI goes completely away without any warning.
Also, I am finding many drawing issues when it comes to the controls used for setting the numeric values. Sometimes the controls appear squeezed in and other times they do not appear to be that way. Very inconsistent drawing and behaviors. Many times when I am using the slider on the control the designer crashes. Sometimes the numeric value does not even show up in the text portion of the control. Definately looks like this is half baked code.
To the point, I am just wondering if anyone has solutions to resolve the crashes or if anyone knows if Infragistics has a patch for this.
Thanks!
Durant
all the crashing issues should be resolved in the latest hotfix versions. as for the sliders in the gauge designer, there have been some bugs reported and fixed, so the hotfix might help ... but if you find a problem, we'd be grateful if you posted steps to reproduce here, or through infragistics developer support.
