645
Pagebreak inserted when I add table to a Documents.word.document
HI,
I am trying to add a table to a document after a paragraph using "Infragistics.Documents.Word" with the code inserted below.
However, the table always ends up on a second page instead of right after the paragraph. What am I doing wrong?
Kind regards
Kai-Inge
Private Sub UltraButton2_Click(sender As Object, e As EventArgs) Handles UltraButton2.Click
Dim docTest = New Document()
'doc.DocumentPropertie()
'***** FONTS
Dim font As Infragistics.Documents.Word.Font = docTest.CreateFont()
font.Reset()
font.Bold = False
font.Size = 11
font.Name = "Arial"
' Add a paragraph to the Document
Dim para As Paragraph = docTest.ContentBlocks.AddParagraph()
Dim sec As Section = docTest.Sections.Add(para)
' Header
' Add text to Paragraph
para.ContentRuns.AddNewLine()
para.ContentRuns.AddTextRun("Some text", font)
para.ContentRuns.AddTextRun("Some text")
' table
Dim tblSampleDescr As Table = docTest.ContentBlocks.AddTable
tblSampleDescr.Properties.BorderProperties.Style = TableBorderStyle.[Double]
Dim columnSample As TableColumn = tblSampleDescr.Columns.Add()
Dim rowSample As TableRow = tblSampleDescr.Rows.Add()
Dim cell1forSampleRow As TableCell = tblSampleDescr.Rows(0).Cells.Add()
Dim paraSampleRowCell1 As Paragraph = cell1forSampleRow.ContentBlocks.AddParagraph()
paraSampleRowCell1.Properties.Alignment = ParagraphAlignment.Left
paraSampleRowCell1.ContentRuns.AddTextRun("Sample no.1", font)
Dim cell2forSampleRow As TableCell = tblSampleDescr.Rows(0).Cells.Add()
Dim paraSampleRowCell2 As Paragraph = cell2forSampleRow.ContentBlocks.AddParagraph()
paraSampleRowCell2.Properties.Alignment = ParagraphAlignment.Left
paraSampleRowCell2.ContentRuns.AddTextRun("--Some info on sample no. 1--", font)
'**** Footer
Dim footerPara As Paragraph = sec.FooterAllPages.ContentBlocks.AddParagraph()
' The footer text alignment is set to right
footerPara.Properties.Alignment = ParagraphAlignment.Right
' Display Text in Footer
footerPara.ContentRuns.AddTextRun("some strFooterText")
' Add Page numbers to the Footer
footerPara.ContentRuns.AddPageNumberField(PageNumberFieldFormat.Ordinal)
docTest.Save("c:\testfolder\test.docx")
System.Diagnostics.Process.Start("c:\testfolder\test.docx")
End Sub
  • 23930
    I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
  • 23930
    Verified Answer
    Thank you for contacting Infragistics Developer Support.
    What you could do in order to prevent this behavior is, instead of using a new section created by you, to use the FinalSection property of the word document. To do that remove this line:
    And change the following line:
    To:
    Dim footerPara As Paragraph = docTest.FinalSection.FooterAllPages.ContentBlocks.AddParagraph()
    Please let me know if you have any additional questions.
