60
Can't modify form in design mode
I was using the version 2013 and upgraded it to 2014 on Visual Studio 2012. Since then, i can't add or modify an infragistics component in a form.
My coworkers don't have the problem (We used the same install of infragistics).
My project references the copy of the DLLs which are stored and versionned in a folder.
I tried multiple solutions (cleaning the licxfile, adding and removing the dll from references, trying to register them in gac, etc...)
Finally i found a workaround, when i copy the dll from my install folder (C:\Program Files (x86)\Infragistics\2014.1\Windows Forms\CLR4.0\Bin) in the project folder it works, but it doesn't work anymore for my coworkers who can't edit after the update.
Can you help me to fix this problem so i don't have to use the workaround everytime ?
Alex
