This can be easily reproduced by adding the following line to the InitializeLiveTileViews() method in the LiveTileViewVB sample project.
_wideTile.Logo.ShortName = "test"
Is this by design? If there's no immediate workaround/fix for this at this time, could you suggest an alternative approach for displaying the following contents in a wide live panel?
Header (Heading Text)2 columns of Text Body2 columns of Text Body2 columns of Text Body2 columns of Text Bodysmall text
Thank you.
Our developers have reviewed this issue and determined that the UltraLiveTileView is behaving as designed. When you display a logo on a tile, the last row of text will not be displayed.
Please let me know if you have any other questions about this.
Thank you for contacting Infragistics.
I have reproduced this behavior and I have submitted it to our developers for them to research. I have created support case CAS-140781-Y7L2X3 to track this. You can view this support case by clicking the "Account" link in the upper-right corner of the page and then clicking "Support Activity".
