220
Series Binding
I have attached the Chart image where i have problem in series chart binding and also find the below coding for series binding which i have used kindly go through the code and chart and help me as soon as possible
problem:
In the stack area chart for a new bar doesnt start from the zero position.
Code:-
For i As Integer = 0 To oDs.Tables(1).Rows.Count - 1
dtSeries = oDs.Tables(1).Clone
drRow = dtSeries.NewRow
drRow(0) = oDs.Tables(1).Rows(i)(
"Block_Id")
drRow(1) = oDs.Tables(1).Rows(i)("DEMAND_ORDER_ID")
drRow(2) = oDs.Tables(1).Rows(i)("STARTDTE")
drRow(3) = oDs.Tables(1).Rows(i)("ENDDTE")
drRow(4) = oDs.Tables(1).Rows(i)("MFG_QTY_IN_BLOCK")drRow(5) = oDs.Tables(1).Rows(i)("BLOCK_SIZE")
dtSeries.Rows.Add(drRow)
drRow = Nothing
"Block_Id")
drRow(2) = oDs.Tables(1).Rows(i)("ENDDTE")
drRow(3) = oDs.Tables(1).Rows(i)("STARTDTE")
If dtSeries.Rows.Count > 0 Then
series = GetNumericSeriesBound1(dtSeries)
myColumnLayer1.Series.Add(series)
Me.UltraChart1.CompositeChart.Series.Add(series)
End If
Next
Private Function GetNumericSeriesBound1(ByVal table As DataTable) As NumericTimeSeriesDim series As New NumericTimeSeries
series.Label = table.Rows(0)(0)
series.Key = table.Rows(0)(0)
' this code populates the series from an external data source
series.Data.DataSource = table
series.Data.TimeValueColumn = "STARTDTE"
'series.Data.LabelColumn = "Label Column"
series.Data.ValueColumn = "MFG_QTY_IN_BLOCK"
Return series
End Function
Thanks in Advance,
Suresh
