Since last week we are using an new version of infragistics 2014.1, before we've used infragistics 2010.1.Our software is build for europe purposes and we are using specific kind of format strings.Before the update the format strings we're build up as followed: private void ultraGridExcelExporter_InitializeColumn(object sender, Infragistics.Win.UltraWinGrid.ExcelExport.InitializeColumnEventArgs e) { //Adds a currency in excel if (e.Column.Format == "C" || e.Column.Style == Infragistics.Win.UltraWinGrid.ColumnStyle.Currency) { e.ExcelFormatStr = "€ ###,###,##0.00"; } else if ((e.Column.MaskInput ?? "").Contains("%")) { e.ExcelFormatStr = "0.##"; } }Our grid:In the Excel export was the following format string attached to the column:Now with the new infragistics the format string is build up wrong:We think this is due to the new version of Infragistics because we didn't change the code.We already tried to set the formatinfo of the column to the dutch cultureinfo but this didn't help:private void ultraGridExcelExporter1_InitializeColumn(object sender, Infragistics.Win.UltraWinGrid.ExcelExport.InitializeColumnEventArgs e) { //Adds a currency in excel if (e.Column.Format == "C" || e.Column.Style == Infragistics.Win.UltraWinGrid.ColumnStyle.Currency) { e.ExcelFormatStr = "€ ###,###,##0.00"; e.Column.FormatInfo = new System.Globalization.CultureInfo("NL-nl"); } else if ((e.Column.MaskInput ?? "").Contains("%")) { e.ExcelFormatStr = "0.##"; } }
Please check again to make sure all of your images were attached properly to this forum post. It looks like two or more may have not been uploaded properly. You can instead zip them and label them as such.
Also, would it be possible to provide us with a sample/steps that reproduces this behavior?
Hello Micheal,
I think we found the "error" before the update to infragistics 2014.1 the format string automatic was convert to the right culture.But with the newest version the format string is exactly taken over to excel which is good after all.We only needed to change the format string to the right format.
Gijs
Thank you for informing us of this. In case you have any additional questions regarding exporting the UltraGrid to Excel please update this thread or create a support case by signing in through your account and clicking support activity.
Thanks again.
