I have a winform that has two radio buttons. Depending on the button that is checked a certain line chart should display. For various reasons I can not use separate winforms.
The radio button is checked as follows:
private void radioButtons_CheckedChanged(object sender, EventArgs e) { this.ultraChart1.DataSource = GetColumnData(uI, noiseCriteria, newPath, roomCriteria); this.ultraChart1.DataBind(); }
The graphs currently are made as follows:
private DataTable GetColumnData(int[] userInput, int NC, string path, int RC) { if (radioButton1.Checked) { // Make annotation for NC # Infragistics.UltraChart.Resources.Appearance.PaintElement paintElement1 = new Infragistics.UltraChart.Resources.Appearance.PaintElement(); Infragistics.UltraChart.Resources.Appearance.EllipseAnnotation ellipseAnnotation1 = new Infragistics.UltraChart.Resources.Appearance.EllipseAnnotation(); ellipseAnnotation1.Height = -1; ellipseAnnotation1.Location.Column = 6; ellipseAnnotation1.Location.LocationX = 0; ellipseAnnotation1.Location.LocationY = 0; ellipseAnnotation1.Location.Row = 11; ellipseAnnotation1.Location.Type = Infragistics.UltraChart.Shared.Styles.LocationType.RowColumn; ellipseAnnotation1.Location.ValueX = 0; ellipseAnnotation1.Location.ValueY = 0; ellipseAnnotation1.PE = paintElement1; ellipseAnnotation1.TextStyle.HorizontalAlign = System.Drawing.StringAlignment.Center; ellipseAnnotation1.Width = -1; this.ultraChart1.Annotations.Annotations.Add(ellipseAnnotation1); ellipseAnnotation1.Text = "NC: " + NC.ToString();
DataTable mydata = new DataTable(); // Define the columns and their names mydata.Columns.Add("Series Labels", typeof(string)); mydata.Columns.Add("63", typeof(int)); mydata.Columns.Add("125", typeof(int)); mydata.Columns.Add("250", typeof(int)); mydata.Columns.Add("500", typeof(int)); mydata.Columns.Add("1k", typeof(int)); mydata.Columns.Add("2k", typeof(int)); mydata.Columns.Add("4k", typeof(int)); // Add the rows of data mydata.Rows.Add(new Object[] { "NC 65", 80, 75, 71, 68, 66, 64, 63 }); mydata.Rows.Add(new Object[] { "NC 60", 77, 71, 67, 63, 61, 59, 58 }); mydata.Rows.Add(new Object[] { "NC 55", 74, 67, 62, 58, 56, 54, 53 }); mydata.Rows.Add(new Object[] { "NC 50", 71, 64, 58, 54, 51, 49, 48 }); mydata.Rows.Add(new Object[] { "NC 45", 67, 60, 54, 49, 46, 44, 43 }); mydata.Rows.Add(new Object[] { "NC 40", 64, 56, 50, 45, 41, 39, 38 }); mydata.Rows.Add(new Object[] { "NC 35", 60, 52, 45, 40, 36, 34, 33 }); mydata.Rows.Add(new Object[] { "NC 30", 57, 48, 41, 35, 31, 29, 28 }); mydata.Rows.Add(new Object[] { "NC 25", 54, 44, 37, 31, 27, 24, 22 }); mydata.Rows.Add(new Object[] { "NC 20", 51, 40, 33, 26, 22, 19, 17 }); mydata.Rows.Add(new Object[] { "NC 15", 47, 36, 29, 22, 17, 14, 12 }); // Will be dynamic based on read in values mydata.Rows.Add(new Object[] { "User Input", userInput[0], userInput[1], userInput[2], userInput[3], userInput[4], userInput[5], userInput[6] }); /* // Overriding NC lines to be grey for (int i = 0; i < 11; i++) { Override override1 = new Override(); override1.Column = -2; // all columns override1.Row = i; // row i override1.PE = new PaintElement(Color.Gray); this.ultraChart1.Override.Add(override1); } */ // Overriding User Input to be Red Override override1 = new Override(); override1.Column = -2; // all columns override1.Row = 11; // row i override1.PE = new PaintElement(Color.Red); this.ultraChart1.Override.Add(override1);
this.ultraChart1.InvalidateLayers(); ultraChart1.TitleTop.Text = path; return mydata; } else { // Make annotation for RC Speech Interference Level # Infragistics.UltraChart.Resources.Appearance.PaintElement paintElement1 = new Infragistics.UltraChart.Resources.Appearance.PaintElement(); Infragistics.UltraChart.Resources.Appearance.CalloutAnnotation calloutAnnotation1 = new Infragistics.UltraChart.Resources.Appearance.CalloutAnnotation(); calloutAnnotation1.Height = -1; calloutAnnotation1.Location.Column = 4; calloutAnnotation1.Location.LocationX = 0; calloutAnnotation1.Location.LocationY = 0; calloutAnnotation1.Location.Row = 0; calloutAnnotation1.Location.Type = Infragistics.UltraChart.Shared.Styles.LocationType.RowColumn; calloutAnnotation1.Location.ValueX = 0; calloutAnnotation1.Location.ValueY = 0; calloutAnnotation1.PE = paintElement1; calloutAnnotation1.TextStyle.HorizontalAlign = System.Drawing.StringAlignment.Center; calloutAnnotation1.Width = -1; this.ultraChart1.Annotations.Annotations.Add(calloutAnnotation1); calloutAnnotation1.Text = "SIL: " + RC.ToString(); int speechInterferenceLine = RC; DataTable mydata = new DataTable(); // Define the columns and their names mydata.Columns.Add("Series Labels", typeof(string)); mydata.Columns.Add("63", typeof(int)); mydata.Columns.Add("125", typeof(int)); mydata.Columns.Add("250", typeof(int)); mydata.Columns.Add("500", typeof(int)); mydata.Columns.Add("1k", typeof(int)); mydata.Columns.Add("2k", typeof(int)); mydata.Columns.Add("4k", typeof(int)); // Add the rows of data mydata.Rows.Add(new Object[] { "RC 50", 70, 65, 60, 55, 50, 45, 40 }); mydata.Rows.Add(new Object[] { "RC 45", 65, 60, 55, 50, 45, 40, 35 }); mydata.Rows.Add(new Object[] { "RC 40", 60, 55, 50, 45, 40, 35, 30 }); mydata.Rows.Add(new Object[] { "RC 35", 55, 50, 45, 40, 35, 30, 25 }); mydata.Rows.Add(new Object[] { "RC 30", 50, 45, 40, 35, 30, 25, 20 }); mydata.Rows.Add(new Object[] { "RC 25", 45, 40, 35, 30, 25, 20, 15 }); mydata.Rows.Add(new Object[] { "User Input", userInput[0], userInput[1], userInput[2], userInput[3], userInput[4], userInput[5], userInput[6] }); mydata.Rows.Add(new Object[] { "Rumble Limit", speechInterferenceLine + 25, speechInterferenceLine + 20, speechInterferenceLine + 15, speechInterferenceLine + 10, null, null, null }); mydata.Rows.Add(new Object[] { "Hissy Limit", null, null, null, null, speechInterferenceLine + 3, speechInterferenceLine + -2, speechInterferenceLine - 7 }); mydata.Rows.Add(new Object[] { "Reference Line", speechInterferenceLine + 20, speechInterferenceLine + 15, speechInterferenceLine + 10, speechInterferenceLine + 5, speechInterferenceLine, speechInterferenceLine - 5, speechInterferenceLine - 10 }); // Overriding user input line to be Orange Override override2 = new Override(); override2.Column = -2; // all columns override2.Row = 6; // User Input override2.PE = new PaintElement(Color.Orange); this.ultraChart1.Override.Add(override2); // Overriding rumble line to be red Override override3 = new Override(); override3.Column = -2; // all columns override3.Row = 7; // max permitted override3.PE = new PaintElement(Color.Red); this.ultraChart1.Override.Add(override3); // Overriding hiss line to be pink Override override4 = new Override(); override4.Column = -2; // all columns override4.Row = 8; // rumble limit override4.PE = new PaintElement(Color.Pink); this.ultraChart1.Override.Add(override4); // Overriding Reference lines to be green Override override5 = new Override(); override5.Column = -2; // all columns override5.Row = 9; // reference line override5.PE = new PaintElement(Color.Green); this.ultraChart1.Override.Add(override5); this.ultraChart1.InvalidateLayers(); ultraChart1.TitleTop.Text = path; return mydata; } }
The problem is that the graphs start to do unwanted things. Lines turn the wrong color when buttons are checked multiple times because it is still getting old information from last line overrides. Annotation are hard to read because they get thicker from not being erased from the last time, or annotation don't erase at all even though they are no longer relevant.
Thank you in advance.
Milko,
You are an asset to infragistics. I hope they pay you well :) Thank you for all the help. I am going to check out some more of your development tools given that the support has been so excellent from you.
Amanda
Hello Amanda,
To override line appearance on radio buttons switch you need to clear LineAppearances collection. What your code does now is adding new line appearance line styles on each switch of radio buttons. Please find attached a sample with line appearances cleared before each iteration adding new ones in clear collection.
Please let me know if this is what you are looking for or if I am missing something.
Sorry I was away for a bit. I am still not able to override lineappearances.
The code I have right now looks like this:
private void radioButtons_CheckedChanged(object sender, EventArgs e) { if (this.ultraChart1.Override.Overrides.Count != 0) { //removes all overrides this.ultraChart1.Override.Overrides.Clear(); // removes all annotations this.ultraChart1.Annotations.Annotations.Clear(); } this.ultraChart1.DataSource = GetColumnData(uI, noiseCriteria, newPath, roomCriteria); this.ultraChart1.DataBind(); if (radioButton2.Checked) { // Make line dashed for rumble limit for (int i = 0; i <= 8; i++) { var lineApp = new LineAppearance(); if (i == 8) { lineApp.LineStyle = new LineStyle(LineCapStyle.Round, LineCapStyle.Round, LineDrawStyle.Dash); } else { lineApp.LineStyle = new LineStyle(LineCapStyle.Round, LineCapStyle.Round, LineDrawStyle.Solid); } ultraChart1.LineChart.LineAppearances.Add(lineApp); } } else { MessageBox.Show("things that work are awesome."); // Make line dashed for rumble limit for (int i = 0; i <= 11; i++) { var lineApp = new LineAppearance();
ultraChart1.LineChart.LineAppearances.Add(lineApp); } } }
When I click the first time it does the right thing, but on subsequent clicks the dashed line stays on both charts.
Please let me know if you need my further assistance on this matter.
If I understand you correct you need apply custom appearances to annotations and axis lines.
To apply custom appearance to annotation you need to set your paintElement1 properties like fill, stroke and so on. You can also add some customization to annotation TextStyle property. If you want to display different annotations in both charts you need to clear annotations collection when you change charts, exactly as you clear overrides collection.
To apply custom appearance to axis lines you need add some customization to UltraChart Axis property.
Please note there are no overrides for annotations and axis lines.
Please find attached revised sample solution with customized annotations and major grid lines.
