1350
Change size of popup menu arrow
I need to change the litle arrow in Popup-Controls in a Ribbon. I tried to use a creation filter but with no luck.
I can change the size of the drop down button, but not the image used for the arrow, see the image
This is my code so far:
// Increase DropDown button
PopupToolDropDownButtonUIElement dropDownBtn =
                    parent.ChildElements[1] as PopupToolDropDownButtonUIElement;
if(dropDownBtn != null) {
    // Increase size of DropDown-Button
    dropDownBtn.Rect = new Rectangle(dropDownBtn.Rect.X - 10,
                                    dropDownBtn.Rect.Y,
                                    dropDownBtn.Rect.Width + 10,
                                    dropDownBtn.Rect.Height);
    // Increase Arrow element
    if(dropDownBtn.HasChildElements) {
        dropDownBtn.ChildElements[0].Rect = new Rectangle(dropDownBtn.ChildElements[0].Rect.X - 5,
                                                        dropDownBtn.ChildElements[0].Rect.Y - 5,
                                                        dropDownBtn.ChildElements[0].Rect.Width + 10,
                                                        dropDownBtn.ChildElements[0].Rect.Height + 10);
        // Set new image --> Doesn't work --> Exception !!
        //(dropDownBtn.ChildElements[0] as ArrowUIElement).Image = ......;
    // Decrease text label size
    parent.ChildElements[0].Rect = new Rectangle(parent.ChildElements[0].Rect.X,
                                                parent.ChildElements[0].Rect.Y,
                                                parent.ChildElements[0].Rect.Width - 10,
                                                parent.ChildElements[0].Rect.Height);
Is this possible? Any help?
Thanks!
Regards
Michael
