335
Problem with OrientationAngle after installing hotfix
I just installed a hotfix for version 7.3 (hotfix 7.3.20073.1052).  After doing this I am having trouble setting the OrientationAngle on the X-Axis of a column chart.  When I change the angle I notice that it no longer rotates around the point that it is supposed to.
Example
If I set the HorizontalAlign to Near and the VerticalAlign to Center, it rotates the text around a center point ( [ABC.DEF] instead of [ABCDEF.] )
 Is this fixed in a different version?
  • 17605
    Yes, we've made changes in this, because we've had a lot of bugs related to the axis labels layout. It is really hard to make this layout work good in every situation. But I agree with your point that it is good to have functionality for rotation not only at the center of the label.
