519
BarChart - Show DATA_VALUE in the Legend
I am creating a BarChart and a PieChart.
I need to show in the legend the following values: ITEM_LABEL and DATA_VALUE.
In the PieChart, I set up the "Legend > FormatString" property as "<ITEM_LABEL> (<DATA_VALUE: ###, ###, ## 0>)" and it worked correctly.
For the BarChart, the same configuration does not work ...
Hovering in each bar, the value of all items of the legend is changed to the value of the bar that was the last mouse.
What is the correct configuration to display the value of the bars in the legend?
For the tooltip, the same setup worked for the two graphs.
