20
Threading issue: NullReferenceException in DrawChildElements
Hallo,
we use the WinGrid in a Windows Forms application and have a threading issue there. We get a call via .NET Remoting which starts a seperate thread. This thread sets the datasource of the grid. At that moment the main thread seems to get a command to paint the grid again which leads to the following just 200 milliseconds after the setter of the datasource has finished:
Exception System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
   bei Infragistics.Win.UIElement.DrawChildElements(UIElementDrawParams& drawParams)
   bei Infragistics.Win.UIElement.DrawElement(UIElementDrawParams& defaultDrawParams)
   bei Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   bei Infragistics.Win.UIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   bei Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
   bei Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize)
   bei Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   bei Infragistics.Win.UltraWinGrid.UltraGridUIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   bei Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
   bei Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe)
   bei System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   bei System.Windows.Forms.Control.WmPaint(Message& m)
   bei System.Windows.Forms.Control.WndProc(Message& m)
   bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) with Message: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
StackTrace:    bei Infragistics.Win.UIElement.DrawChildElements(UIElementDrawParams& drawParams)
We tried locking (lock(this)) in the datasource setter, in the OnPaint (which is not called), in a handler of the paint-Event and in a handler of the paint-Event of the parent control but nothing helped. We tried calling SuspendLayout and ResumeLayout in the setter but the problem occurs afterwards. For all the other controls (UltraEditor ...) we could solve the thread issues by calling Invoke but for the grid we don't know what to invoke.
Any suggestions?
