how to add checked items in checkedlistbox to ultrawingrid programmatically and delete the row same on uncheck?
private void lstManagers_ItemSelectionChanged(object sender, ItemSelectionChangedEventArgs e) {
classData Service = new cAssetsData(); DataTable dt = Service.Method((int)e.SelectedItems[0].Tag); this.ultrawingrid1.DataSource = dt; for (int i = 0; i < checkedlistbox1.Items.Count; i++) { dt.Rows.Add(checkedlistbox1.Items[i]); }
I am just checking about the progress of this issue. Let me know If you need my further assistance on this matter?
UltraListView gives your ability to use ItemCheckStateChnaged if you need to check when item state was changed or ItemCheckStateChnaging – before item check state was changed. More information about the events you will find on the following links:
http://help.infragistics.com/doc/WinForms/2014.2/CLR4.0/?page=Infragistics4.Win.UltraWinListView.v14.2~Infragistics.Win.UltraWinListView.UltraListView~ItemCheckStateChanged_EV.html
http://help.infragistics.com/doc/WinForms/2014.2/CLR4.0/?page=Infragistics4.Win.UltraWinListView.v14.2~Infragistics.Win.UltraWinListView.UltraListView~ItemCheckStateChanging_EV.html
I hope that this will helps you.
I can't find ItemCheck event in infragistics equivalent of checkedlistbox i.e (Infragistics.Win.UltraWinListView.UltraListViewStyle.List;),,Which event is equivalent to the ItemCheck event in infragistics ?
yup,issue has been resolved..thank you
Thank you so much for your help.Really,appreciate that.
