270
Set font for entire application programmatically through style
Is there a way to access the base role through code and set the font size?  I would like to allow the user to change the font size through a slider bar and save that setting to the .isl file.  Thanks in advance.
  • 29105
    Suggested Answer
    Yes it is possible to modify the base UI Role in code. However I like to add that we don't have any documentation or examples of this being implemented.  Therefore I strongly recommend creating presets (several style libraries) that update and load in the application based on user some user actions and take effect.
    Thus, I believe the answer to your question has been discussed on another forum post here:
    http://ko.infragistics.com/community/forums/t/16483.aspx
