I am using an infragistics ultraComboEditor control with autoCompletemode property set to suggest. and ButtonDisplayStyle property set to Never.
when i type a character or string in this control a list with possible data will be displayed but when i select one of the suggestion, text will disappear and I am not able to retain the selected data on the editor.
please find the attached screen shots.
image1: when characters are typed in the editor.
image2: when one of the options is selected.
Please suggest what can be done regarding this
Hello Chitra,
I am following up to see if you need any further assistance with this issue.
Please let me know if you have any other questions about this.
Thank you for contacting Infragistics.
I created the attached sample project in order to test this issue. I did not reproduce the issue when I ran the sample. I'd like you to run the sample on your end and see if it reproduces the issue for you. When the window opens, start typing "Item" into the editor and select one of the items in the drop down.
If my sample does not reproduce the issue, either modify my sample so it reproduces the issue or send me your sample so I can look at it.
If my sample does reproduce the issue for you, let me know which version of our controls you're using.
