240
AutoScaleMode does not resize column widths
I am trying to get our application to auto scale property.  I have the entire application working correctly except that columns widths are not re-sized when the ScaleControl() is called from the framework.  The result is a grid with the font size being sized correctly but the widths not adjusting.  I was wonder why this is not part of the control.  All other controls seem to re-size correctly.  I don't see a easy way to achieve this either because if I scale the widths I have no way of knowing if the widths have already been scaled.  It seems that there would need to be a property of some kind to tell whether or not the column should be re-sized or has already been re-sized.  Thanks in advance.
Parents
No Data
Reply
  • 2165
    Hello Derek,
    I am just checking about the progress of this issue. Let me know If you need our further assistance on this  issue?
Children
No Data
