I have a scenario where the cell of a column in a grid with 7 bands is editable or read-only based on a condition. Also, if the child cell is editable then make the parent cell also editable but if all children cells are read-only then only make the parent cell read-only.
I am able to alter the Activation of a cell at the lowest band i.e. band = 7 but not for higher bands, it always stays as read-only. Below is the InitializeRow event code -
detailBand = 7;
if (e.Row.Band.Index == detailBand) { double manualVolume = Helper.ParseDoubleFromObject(e.Row.Cells["ManualVolume"].Value); int leaseNum = Helper.ParseIntFromObject(e.Row.Cells["LeaseNumber"].Value); int? volType = null; try { if (e.Row.Cells["VolumeType"] != null) volType = Helper.ParseIntFromObject(e.Row.Cells["VolumeType"].Value); } catch (System.ArgumentException ex) { if (ex.ParamName == "key" && ex.Message.Contains("Key not found")) volType = -1; else throw ex; } if (manualVolume == 0.0 && (leaseNum == 1 || leaseNum == 2 || leaseNum == 3 || leaseNum == 5 || leaseNum == 6 || volType == 8)) { e.Row.Cells["ManualVolume"].Activation = Activation.NoEdit; e.Row.Cells["ManualVolume"].Appearance.BackColor = Color.LightGray; } else { e.Row.Cells["ManualVolume"].Activation = Activation.AllowEdit; e.Row.Cells["ManualVolume"].Appearance.BackColor = Color.White; } } else { int? isEdit = Helper.ParseIntFromObject(e.Row.Cells["IsEdit"].Value); if (isEdit != null && isEdit > 0) { e.Row.Cells["ManualVolume"].Activation = Activation.AllowEdit; e.Row.Cells["ManualVolume"].Appearance.BackColor = Color.White; } else { e.Row.Cells["ManualVolume"].Activation = Activation.NoEdit; e.Row.Cells["ManualVolume"].Appearance.BackColor = Color.LightGray; } }
Am I missing something here? What other properties should I be on look out for which may prevent what I am trying to achieve?
Hello Priyam,
Thank you for your response.
For the benefit of our other customers, it would be helpful if you could post your solution to the issue and mark that as the answer.
Please let me know if you have any other questions about this.
I was able to resolve the issue myself. If possible you may delete this thread.
I am following up to see if the issue has been resolved or if you still need assistance with this.
Thank you for contacting Infragistics.
It appears the issue you're describing is specific to a certain scenario. It would be very helpful if you could provide a sample project which demonstrates the issue.
