1170
Properties tab not visible when loading theme
Usually, when one loads a theme into the AppStylist and selects the role of an element, there are two tabs in the two tabs in the bottom panel: Properties and Common States.But when I load the attached theme, the properties tab is not visible for any element.
Could you please explain the reason behind this behaviour and provide a solution?
DefaultTheme.rar
