HiI have a ultrawingrid consisting of two binded checkbox columns only. I want to make those columns mutually exlusive so if i check one the other have to be unchecked. To achieve that i am using AfterCellUpdate event to update the binded object, this is working fine except that this event does not fire until the user leave the cell and i want to perform the update the object and refresh the control after the user had checked or unchecked any checkbox.Question i short, can the object be updated and the grid row refreshed just after the user check\uncheck each cell?
You could also avoid updating the row by using the Text property of the cell, instead of the Value.
Hi Elio,
Thank you for contacting Infragistics Developer Support.
I am glad that you have resolved your issue. Let me know if you have any additional questions.
Sincerely,
Thanks very much sr, CellChange was the correct event to handle.
Just one thing, to actually refresh the cells and reflect the object values immediately after checkor unchek, i have to call e.Cell.Row.Update():
Private Sub ProcessCollectionUltraGrid_CellChange(sender As System.Object, e As Infragistics.Win.UltraWinGrid.CellEventArgs) Handles ProcessCollectionUltraGrid.CellChange e.Cell.Row.Update()'prevent the same event to fire while updating the binded object in code ProcessCollectionUltraGrid.EventManager.SetEnabled(Infragistics.Win.UltraWinGrid.GridEventIds.CellChange, False) _rolePermissionsPresenter.UpdateRolePermission(e.Cell) ProcessCollectionUltraGrid.EventManager.SetEnabled(Infragistics.Win.UltraWinGrid.GridEventIds.CellChange, True)
End Sub
Hello Elio
I am just checking about the progress of this issue. Let me know if you need my further assistance on it.
Milko
Developer Support Engineer
www.infragistics.com/support
Hello Elio,
You are on the right way. What you have to change is the event you are using. To achieve immediate update of the other checkbox you need to use CellChange event.
Please find attached a sample solution and let me know if this is what you are looking for or if I am missing something.
