538
UltraWinTree BringIntoView is deathslow when using images
Hi all,
I use .NET 1.1, NedAdvantage 2007.1
I have to load 6000 nodes into an ultrawintree, deepest level is 4. All nodes were added using the AddRange method except the first node. Icons are assigned to the node by means of an index from the imagelist. When i call the BringIntoView method after filling the tree, it could take up to 6 seconds before the method completes. When i do not set an image index, the BringIntoView method terminates immediately.
Has anyone experienced this and how do i get arround this problem?
 Regards
 Peter
