455
ultraDropDown as a column field
I would like for the resources column of the ultraWinGanttView to display a dropdown box instead of a text box.  I have added the code below, but it keeps the gantt chart itself from rendering.  What am I missing?
partial class BindingForm
        public Infragistics.Win.UltraWinGrid.UltraDropDown resourcesDropDown;
     private void InitializeComponent()
           this.resourcesDropDown = new Infragistics.Win.UltraWinGrid.UltraDropDown();
           this.resourcesDropDown.DataSource = terminal.resourceList;
           this.resourcesDropDown.DisplayLayout.Bands[0].Columns.Add("Resource");
           this.resourcesDropDown.DisplayMember = "Resource";
           this.resourcesDropDown.ValueMember = "Resource";
           this.ultraGanttView1.GridSettings.ColumnSettings[TaskField.Resources].ValueList = this.resourcesDropDown;
In another Terminal, I have the list initialized this way:
public class Terminal
     public List<string> resourceList;
    public void Init()
            resourceList = new List<string>();
            resourceList.Add("041.000.031.012");
            resourceList.Add("041.000.031.013");
            resourceList.Add("041.000.031.014");
Thanks in advance,
Myca
  • 21795
    Verified Answer
    Hello Myca,
    I am just checking about the progress of this issue. Let me know if you need my further assistance on it.
  • 21795
    Verified Answer
    Hello Myca,
    I have implemented a sample solution with UltraGanttView. I have added your custom Terminal class and UltraDropDown. What I did not see in your implementation was declaration and initialization of terminal variable you used as DataSource for your UltraDropDown. This is why I have added these to your code:
    Terminal terminal = new Terminal();
    terminal.Init();
    After this addition there are all the values from terminal resourceList in resource column of the grid.
    Please find attached a sample solution I have worked on.
    Please let me know in this is what you are looking for or if I am missing something.
    Thank you for contacting Infragistics.
    CAS-144955-N7Q0K6.zip
