I have recently upgraded from 2006 v2 to 2008 v2 and I am trying to work on the design of some of my grids. Previously I used the UltraWinGrid Layout Wizard to load the previously saved layout into the grid and then make my changes before saving the layout back to the file.
Now when I try this I get to Step 3 of 5 of the wizard and select my layout file and then the Next button is disabled so that I cannot progress. I thought it may be due to the layout files being saved in an old version so I completely recreated the layout for one of my grids and then saved the layout to a file. If I try and load that file I still get the issue with the next button not being enabled.
When I load the layout file at runtime everything works fine.
What am I missing here, or is this a bug with the wizard?
Cheers
Sean
I'm having the same issue in 10.1. Is this fixed yet or is there another problem?
Kyle
Hi Sean,
I just tried this out and got the same results. It looks like the layout wizard is broken. You should Submit an incident to Infragistics Developer Support so they can get this fixed.
